98' 5.0 Ranger
Tneff
1998 Ranger, with 5.0. has a 8.8 rear with 3.73's, c4 tranny. I bought it, to help cure my midlife crisis. It had some funky 20" wheels, and lo profile tires. That was the first thing to go, really like the stance with the new wheels and tires. Will be doing some exhaust work, different shifter and some interior work. She is a blast to drive, launch's hard and straight. The manual valve body tranny, took a little getting used to. This is my weekend toy, so no telling how pissed my wife will get.
After driving the truck around for a couple of weeks,and learning more about what was done right and wrong. Some changes are being made, and upgrades being done. The electric cooling fan system that was on it, was a joke. Ordered a new bigger fan, rewired it so it wasn't a complete rats nest. Last night, I finally got to install the temp controller that kicks on at 185 and off at 170. Got all the new gauges in, now to start installing them. Don't really care for the current shifter, so a new B&M Z gate, is waiting for it's date. New exhaust is also waiting to be put it, straight pipes get old real quick. As far as the mechanical aspects of the hooptie, all major systems work as they should. We did get the front end aligned, found out the passenger front spring was cut shorter than the drivers side. Therefore the alignment is slightly out on that side, not gonna play with adding spacers or such. A new set of springs will be put in, currently researching what springs I will use. Want to keep the current stance, will probably go with a custom set.
Spent a lot of time here on the forums looking at different builds, and what interior ideas that were used. Currently, I have a bench seat and no carpet. The bench seat, will find a new home at the dump. A set of buckets will take it's place, along with a custom dash to back of cab console that I am going to design. It will be made to work around the B&M shifter, and include the aftermarket gauges and a slurpee holder and such. The current headliner is good, so that will stay as it. The dash, is out of an explorer. There are several unused knobs/switches that the ranger did not have. Rear defrost/wiper etc. I am going to reuse as many as possible, for current needs. One, will be used for my electric overdrive instead of drilling a new hole in the dash. I also want to put in some minor accent lighting, in the cab. The rear bumper, is going bye bye as well and is being replaced by a custom steel roll pan.
If anyone has any extra ideas floating around, all input is greatly appreciated. This has become a fun toy, and a major attention getter around town here. I had considered getting rid of the 5.0 badges, but really like the second look it gets when folks walk by. :)
XLTsplash
160
CA
2.3L
Looks like a fun to drive Ranger, I like your wheel choice and the 5.0 emblems.
Tneff
Nativetroy
Clermont
2004
Mazda
2.3, 5.4
Looks good. Those wheels work much better. I'm sure it is fun. Does it have any issues hooking?
Tneff
Sorry, for the late response. No issues so far hooking up, surprisingly she hooks pretty hard and straight. There is a little tire spin, but no hopping and shuttering. In a couple weeks, she will get her date with the track. On a prepped track, it may be different.
Tneff
Did some some running around to test the new fan temp controller, water temps are lower now. I did replace the thermostat housing, the old did not have a threaded port and I did not want to run a T to add it. Also, replaced the thermostat with a 180*. So far, everything is working and no smoke :)
Tneff
Picked up a set of black leather seats and a center console this weekend, guess the interior will be black and tan now. Hope to get them installed this week, will get some updated pics as well.
Tneff
Got the new tach installed, went with the green backlight to blend with the other gauges. The Equuis, is a simple install.
Tneff
Finally found a hood I like, that is all metal.
XLTsplash
160
CA
2.3L
Great looking hood. Are you going to paint it body color ?
Tneff
I'm thinking about having the whole truck wrapped, instead of painted. I kind of like the black hood, but will probably make it match.
86 Ranger 5.0
That hood makes it look mean.
