Brad4321
- Sep 20, 2009
- 0
- Columbus, IN
- Ford
- Engine Size
- 2.3L
2001 ranger, 2wd, DJM 4/5 drop kit
Upon trying to install the upper arms, I have noticed two things. First is that the arms are (measured) 1/4" wider at the bushing end than the factories. In the included pictures, one bushing is in place. As you can see, the other one will not line up without a lot of force...and I can't see that polyurethane bushing lasting very long with this much misalignment. I tried both arms and both are wider than the factory mounts. The original upper control arm slides in an out of the frame without interference.
The second issue is I do not see a c-clip in the balljoint, yet I see a place for a c-clip. I am assuming there should be a c-clip installed here, yet there is not? The lowers have a c-clip installed. I have not test fitted the lowers yet...a bit afraid too.
Did I just get a bad set of arms, or are they suppose to be wider? To say the least, this is a bit disheartening.
