98 explorer trans in 95 ranger
95RangerAK
Alaska
FORD
not going so well. shifts harsh, my overdrive light blinks on and off. fluid seems fine but tranny never shifts right and is making me wanna cry. i need to get this truck running any ideas? both autos.
after really looking it up the explorer is a 4 speed 4r70w and the ranger was a 5 speed 5r55e. the connecters didnt all match up for the tranns to ranger. so i plugged in what i could, and the shift linkage. the shift points are all wrong, shifts hard. need help.
Bruce
Southwest Missouri
4.0 SOHC
yep the electronics in the 95 are different than in the 98
umm a 4R70W transmission is only behind a V8 explorer and in noway will it bolt to a 4.0.
95RangerAK
Alaska
FORD
it bolted up and drove my ass home. haha. but yea it is definantly the 4 speed 4r70w bolted up to a 4.0. which in my ranger is the problem as it came with a 5r55e. so i get to put my rangers original tranny back in.
alaskan155
6
washington
FORD
7.3l/4.0l
need to figure out the pinout for the 95 and 98 transmission, if its like the AODE and 4R70w, you can repin the plug that goes to the transmision and it should work, but im not sure on the pinout of either tranny
Earl43P
38
Farmington, Pa
Ford F250 4WD
95RangerAK
Alaska
FORD
its a 5r55e, and it only overheats when i put it in park while running... so i think i am going to just put that back in there because thats the only problem it had, it drove like a sonofabitch, was fast, shifted right, and it was the original tranny i think its going back in and ill just do some repairs on it later down the road if it still has the park overheating problem...
Bent Bolt
4
Edmonton,AB
Supercharged 4.0 SOHC
Solid Axle Swap 4x4
It won't be overheating in park. See your other thread.
