98 ranger parts and compatabolity
jbarmes85
Indiana
Ford ranger
Hi guys I got a 98 ranger 4wd 4.0 I just got in a wreck. I need a front driver steering knuckle and am having trouble locating one seems like that part is discontinued so I'm asking if someone can direct me to a reliable place to purchase or if that year is compatible with any other years
sgtsandman
Aircraft Fuel Tank Diver
TRS 25th Anniversary
12,915
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I believe 1998 was the first year for the torsion bar front suspension. So, the components for that should be the same up through 2011.
Get on a site like Ford Parts that lists all the vehicles and year ranges that part lists as fitting to confirm that.
Part of the reason I caution verifying is I think your front hubs are vaccum operated hubs. So, later Rangers with a live front axle might not be compatable. I don't remember when they did the switch over. So better to be sure before you order the wrong part and can't get the front end back together.
Of course, you could always switch to live axle but that is going to require more money than you might be able afford to spend at the moment.
That would require new CV axles as well as bearings designed for the live axle arrangement. The rest of the setup is the same, if I remember correctly.
jbarmes85
Indiana
Ford ranger
Mine does have a tortorson bar butnits been changed to manual push lock outs you can see where the hose for the vacuum was at least I think that's wat it is. I can find everything before and after but not that year and ford says it's discontinued
sgtsandman
12,915
Aliquippa, PA
Ranger XLT/FX4
Pre-2008 lift/Stock
The hub change out shouldn't matter. It just eliminated the vacuum system.
It might be worth a look at the tech section to see what years has your system. I want to say they switched over to live axle in 2002. But others are more knowledgeable on what changed what year than I am.
JoshT
1,896
Macon/Fort Valley, GA
I'm not surprised that Ford doesn't offer it. The PVH hubs were discontinued in 2001 at the lastest and manufacturers generally only support for about a 10 year period. Some stuff is used on multiple vehicles for a longer period or sit in warehouses for a long time so might seem longer than that for some things.
I am a little surprised that the asfter market doesn;t offer a replacement, but again that knuckle was only used for about three years over 20 years ago. People weren;t even too fond of the PVH system then.
I don't understand why they list the interchange the way they do, but you should be able to use a knuckle from any 98 through mid-2001 Ranger that is equipped with PVH.
If you never want to go back to a functional PVH system you should be able to use a 2001-2003 live axle knuckle as well. Near as I can tell the knuckle is almost identical to the PVH hub, just lacking the vacuum port. Brake rotor and caliper are the same, but the hub and axle are different and the PHV setup has a few extra seals for the vacuum. I've actually got 01-03 live axle hubs and axles installed on my 99 knuckles right now, just removed the unneeded seals and installed the later components.
EDIT: If you don't need new, check out used parts in local junkyards and online. This isn't a wear item, so a used one should be in good shape. Car-part.com can be handy for searching out junkyard inventory, but it might still be worth while calling around since not every yard lists all parts or does good about updating inventory.
rubydist
873
Denver
Ford Ranger FX4
Since they are the same from 98-11, you should easily find one at the junk yard.
JoshT
1,896
For the 2wd, but not for the 4wd. In 2001 they dropped the vacuum port needed for Pulse Vacuum Hubs. In 2004 the position of the caliper mounting bracket holes were relocated to accomidate a larger rotor.
For 4wds... To keep PVH capability and stock brakes a 98-01 knuckle is required. 98-03 can be used with stock brakes if one does not need or care about retaining PVH compatability. 04+ can be used of one does not care about retaining PVH capability and also uses the larger rotors for the 04+ trucks, I think (not positive) the earlier caliper and bracket can still be used.
