99 5r55e to replace 2002 5r55 both 4.0l
kgross
Nampa
Ranger XLT 4x4
Hoping somebody can help me. I found a 99 5r55e out of explorer would be in easy swap in to a 2002 ranger 4x4? Ford has to many different small changes.
Thank you.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
I poop in the furnace.
engine
17
Ashe Co NC
4.0 SOHC
245 75 R16
I did the same thing. It was supposed to be a drop-in and it was, except the 2002 has an additional sensor and there will be no place to plug it in. I was later told that it has to do with an engineering change to the transmission that is supposed to smooth out the 2-3 shift. Not having the sensor causes me no problem except that the computer detects it and causes the o/d off light to flash. I find that the 2-3 shift is just fine as are all of the others. I can easily tell whether o/d is on or off so I just taped over the light! I have found no easy fix or workaround.
kgross
Nampa
Ranger XLT 4x4
Need to figure out what to do, the transmission slips a lot hard to tell what gears work correctly.
8,373
2001 to 2011 5R55E will work in a 2002 Ranger 4.0l, these years have the needed ISS sensor
And must be from 4x4, can't convert 2WD without total rebuild
3.0l and 2.3l Rangers used the 5R44E, just to be clear, so not the same thing
kgross
Nampa
Ranger XLT 4x4
Thank you RonD
engine
17
Ashe Co NC
4.0 SOHC
245 75 R16
If you are willing to put up with the flashing od off lite as I described, I would say go for it if you can't find a newer one. I am very happy with my choice.
Dirtman
13,329
41N 75W
It's up there.
It's down there.
Round.
The ISS sensor is used for the adaptive shift control system. The computer learns the best shift parameters based on the conditions and driving style. They are not rare transmissions so I can't see any logical reason not to use the right one.
kgross
Nampa
Ranger XLT 4x4
Explorer transmission work as well I would assume. I found a 2003 explorer transmission from a 4.0l 4x4 that seems like it would be a perfect choice.
8,373
Yes, 5R55S or W would work, I think it has an extra sensor on the outside case toward the front, and it doesn't have a dipstick or tube
kgross
Nampa
Ranger XLT 4x4
Thank you. without a dipstick how the heck do you check the fluid or change it?
8,373
Some have a bolt that you pulled out, like a manual trans, to check level and refill
Others have a special drain plug that also acted as a level tester and fill with correct hose fitting
Never had one so can't say for sure
May want to check out posts at Explorer forums about it
kgross
Nampa
Ranger XLT 4x4
Thank you for all the info. I can't pass up the deal. $175 for the transmission and TC, less than 100k miles.... Just don't like the idea of no dip stick.
