99 Ranger 4.0l ohv oil filter housing bolt
tcf0415
Need an oil filter housing bolt for my 99 4.0l ohv and they don't make it anymore.....does the housing and bolt from a sohc engine work on the ohv engine? I need this asap! I can find the sohc one all day long but mine is only for years 98-99. The 10 mm bolt stripped out and had to cut it off. it wouldn't budge!!
KBOI
Hot Springs, Arkansas
have you checked the hardware store? Lowes, TSC, Meanards, etc., all have metric fasteners in bulk
tcf0415
This is not a basic fastener it kind of resembles a large banjo banjo bolt with two o-rings and holes and is hollow in the middle to allow the oil to flow through it.
ericbphoto
Overlander in development
16,649
Wellford, SC
6"
Do a Google search for 10mm banjo bolt. The results are simply AMAZING.
Sent from my SM-G960U using Tapatalk
tcf0415
Nope. Wrong....it is not a 10mm banjo bolt. it is specific to this housing....I just want to know if the housing and bolt from a sohc 4.0l will work......and yes I have googled the crap out of this and no straight answer..they look very similar....
tcf0415
Looks like this but with an internal 10 mm allen. My housing and bolt are specific to 98-99 year ohv engines. I just need to know if the housing and bolt from a sohc will work on the ohv engine.. someone must know ...
If you take a whole housing unit and bolt from a SOHC it should work (I'm like 99% sure). I was going to do this myself, just never got to it.
Just keep in mind that if you go with a late enough housing you will have to start using the FL820 (or equivalent) filter, over the FL-1A (or equivalent).
gaz
670
Wa, Bremerton 98310
Ranger 5" (2" suspension), BII 4" suspension
Ranger 5sp, BII A4LD
Ranger 33"/4:10LS, BII 29"/3:73LS
tcf0415:
One thing you could try is go to the Ford dealership have them break out the part and either buy it or get a good look at it, that way you can see if it'll work for you.
tcf0415:
Nobody is going to have that in stock.
I know the mating surfaces of the housings are the same, as well as the oil passages. The only thing I was unsure of was the threads on the bolt to the block.
woodyedmiston
4
Texas
This is suggestion for any odd OEM part, go to your busiest local wrecking yard on Monday morning early - if you can't make that the last hour of business Sat or Sun ... the masses of Saturday people take all sorts of things apart and leave them laying while getting to their part. With a little luck, one or more trucks like yours has been partially disassembled. This keeps you from having to take the entire front engine apart to get at a timing cover for instance or the motor may be out because they wanted ??something?? That makes getting a to and oil mount bolt easier to access too, if that is what you want. I make it a practice to pick up all the discarded bolts and add them to my collection too. That is BTW the only way I found the bolt you are talking about for my '99. Good luck.
