99 ranger 4x4 3.0
Robo Ranger
need help.my sons truck wont turn over,battery fully charged,checked fuses also turn signals or radio want come on .appericate any suggestions he has to leave for school in a few days.
8,370
Welcome to TRS :)
So when you turn on the key do the dash lights all come on?
Is it a Manual or Automatic transmission?
Each has a different kind of switch to disable accidental starting "in gear", so if switch is not "Closed" starter motor will not work.
There is a 50amp fuse in engine fuse box that powers the ignition switch, maybe Fuse #5 but not sure on the number.
And in the Cab fuse box fuse #24, 7.5amp, powers the starter motor relay, but from power coming from the 50amp fuse.
So check that 50amp fuse, it powers radio and turn signals.
You checked the battery cables, I assume, but did you check BOTH ENDS of each cable.
Follow the larger Negative cable to the engine, and make sure connection is clean and tight.
Does the key feel loose or very tight, hard to turn?
The actual ignition switch is under the steering column above the brake pedal.
The Key pushes and pulls on a long rod when it is rotated, this rod is attached to the ignition switch, which is a slider type switch.
The rod slides the ignition switch into its various positions, ACC, OFF, RUN, START
If ignition switch isn't moving as it should then no power to some systems
Robo Ranger
wont turn over
its automatic transmission.going to check that fuse,thanks for reply.
Robo Ranger
wont start
the cables are clean and tight,switch seems to be smooth when turning and seems to have a little spring back like my ranger.after checking the fuse under hood you suggested if thats not it ill look under dash.really appericate the info.
8,370
Automatic has an NSS(neutral safety switch) on the drivers side of transmission, also called "transmission range sensor"
Goggle: ford ranger transmission range sensor
To see what they look like
These rarely fail but the column shifter can get loose on Ford Trucks, all models, so try shifting trans to Neutral and then try to start engine.
Loose shifter gets trans into Park but not far enough to close the NSS so no start in Park.
This wouldn't effect radio or turn signals though, just starter motor.
