A4LD Automatic Transmission Problem
Charris12
Columbus
Ford Ranger XLT
I was driving my 1987 Ford Ranger 2.9L 4x2 Automatic and while in first gear turning into my complex gassing it to proceed home, something popped and now my truck won’t engage any gears at all. Nothing was ever wrong with it but the lag between 3rd and OD but other than that it shifted fine and everything. Trying to see if it’s just a part I can order and fix or I need another transmission? I know it has to be something simple because it was driving and just popped out of gear and won’t engage any but the floor shifter still shifts into gears just doesn’t engage. Please help!!!!!
sgtsandman
Aircraft Fuel Tank Diver
U.S. Military - Active
Ham Radio Operator
12,738
Aliquippa, PA
Ranger XLT/FX4
4.0 SOHC/2.3 Ecoboost
Pre-2008 lift/Stock
31X10.5R15/265/65R17
I moved the thread to the transmissions section for better visibility and searchablity.
I don't know enough about automatic transmissions to provide anything of use. Someone will be along that will be able to help. Welcome to the forum and good luck!
Charris12
Columbus
Ford Ranger XLT
Thanks. Hopefully, someone will help me with this soon
lil_Blue_Ford
6,211
Butler, PA, USSA
4.9L
So if the shifter linkage hasn’t come apart (drivers side of the transmission is where it connects), then it could be something in the transmission. Could be about anything, torque converter, band, seal, something. If it’s anything internal to the transmission, unless it’s low on fluid, the transmission would likely have to come out to fix (about the only exception being if you blew the valve body gasket, which only means dropping the pan).
