Fordman
- Sep 17, 2007
- 6
- Age
- 67
- Ford
Before yanking the tranny, here is a list of "should do's" before pulling the tranny. (1) Check fluid level and condition, if it smells burnt, probably ought to try servicing it. A common problem is if it was ever serviced before, the filter o-rings sometimes get left off or cut, leading to hydraulic leakage, or sucking air instead of fluid.(2) Adjust throttle cable, this can affect shift points, and feel, and prolonged driving with it set wrong will toast them quick. (3) Adjust the bands. All A4LD bands, intermediate and od set two turns out , except for the 4.0L, which the intermediate,rear band set two turns out, and od,front band set 3.5 or 4 turns out. I have never confirmed why other than typically 4.0L trannies use a double wrap band, and suspect that if it was rebuild with the single wrap band, it should have the tighter setting.(4) Pull vachum line off modulator, look for raw fluid indicating a failing modulator. If it has been replaced it most likely will be an adjustable model. (5) Make sure the gear selector linkage or cable is correctly adjusted. This is a common cause of an intermittant overdrive, sluggish engagement, and leads to failure. If problems persist, then you need to gather symptoms.
