mplummer08
- Feb 21, 2016
- 2
- Ford
I have some issues with my 1990 B2 4x4 with the 2.9l and the A4LD. Here they are:
Reverse - Very weak. There is a very slight lurch when put into gear, and the RPMs drop below 500 and sometimes stalls. In reverse I can hang my leg out and push with slight gas and moves decently, but still not what I would consider normal speed.
Shifting - I have no 1-2 shift. Drives in 1 manual or 2 manual just fine. In OD or D there is no up shift. If I'm in 2 manual and shift to D while cruising it drops back to 1st.
Back story: I bought the BII Sept 2014 for $250 with everything pulled out except the engine and dash. The A4LD was on the garage floor beside it. Over time I got all the components installed. Once I got it running I noticed the reverse and shifting issue so I have no idea of the history on the transmission.
So far on the transmission I have changed fluid and filter and upgraded the throttle valve to the one from a shift kit (can't recall the name of the kit), since the original was missing.
Anything yall can think of that would cause this? Or am I looking at 2 individual problems? Governor or Modulator for the shift and reverse servo for the weak reverse?
Any and all suggestions would be appreciated!
Sent from my SPH-L720T using Tapatalk
