Dave
- Mar 13, 2008
- 0
- southern New Jersey
- Ford
- Engine Size
- 3L
My '92 2wd has the ABS sensor on the differential housing. I assume then that it has ABS. Right? The reason I ask is because although it has the sensor, I don't see any of the other usual ABS parts like the ABS control unit with the hydraulic pump, etc. Also the ABS light on the dash does not light when you start the truck. That could be a bad bulb....I gotta' check. Did Ford ever put the ABS sensor in a vehicle but not actually use it? Thanks.
Dave
Dave
