ABS to non ABS
85_Ranger4x4
17,867
SW Iowa
I know the rotors are different from one to the other. I just picked up a ABS D35 for my truck, if I need rotors am I stuck with ABS ones or will non ABS ones work?
My '85 predates front wheel ABS and I have no desire to add it to my truck.
SenorNoob
574
Middle Tennessee
1.5" Front + 4" Rear
245-70-R16
Then you can use either one.. As long as they are for the same application otherwise.
holyford86
Some guy with a problem
610
Plattsburgh, NY
many
33x12.50R15
Only difference between them are the tone rings, and a few bucks
And IIRC the ABS rotors are the cheaper ones.
Even if you use the ABS rotors without things like sensors, wiring, and and ABS module you don't have ABS.
I am using ABS rotors on my 87 because that's what was on the axle when I got it and they just needed cut, not replaced. I sure don't have ABS on my truck just because of it.
Just buy which ever is cheaper.
85_Ranger4x4
17,867
SW Iowa
That was the plan, I haven't priced either yet but was just making sure they didn't change something else.
Nope. Just that tone ring. Like I said, I think I remember seeing the ABS rotors being cheaper anyway, so lots of guys just get them and let the tone rings go along for the ride.
SenorNoob
574
Middle Tennessee
245-70-R16
If you cared, could you just knock the tone rings off?
