Adding PAG oil after A/C repair
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
Seems like those would be good items to snag from wrecking yards.
Denisefwd93
74
South East PA
I would not run the system without them or something you can figure 8 wire around the connection temporarily or permanently imo
fastpakr
2,841
Roanoke, VA
I found the retainer for the high side into the evaporator, but no luck on the low side where it plugs into the accumulator. May have to junk yard that.
wildbill23c
577
Southwestern Idaho
215/70-R14
They do make an oil injector that hooks up to the manifold gauge set, but I found its just easier to pour it in prior to putting everything together. My compressor was filled when I got it, and I added a couple more ounces to the system prior to reassembling everything, far easier to do than mess with the oil injector and risking sucking in some air.
Denisefwd93
74
South East PA
Pour, draw, push oil in, is all good, if air was introduced by accident or carelessness it's not too terrible if they have vacuum pump and do a two or three evacuation procedures.
it's always good to evacuate once, add a holding charge check for leaks evacuate again, for 3 hours or more, 20 mins is really not long enough for a moisture to evaporate completely.
wildbill23c
577
Southwestern Idaho
215/70-R14
Only 3 or more hours if you are charging shop time ;). Otherwise an hour is plenty, unless your vacuum pump sucks...no pun intended LOL.
Denisefwd93
74
South East PA
Then use a micron guage :)
Craig0320
225
Mississppi
Break it right the first time. Fix it better the next time.
I just replaced my compressor on my z71 yesterday. Label stated 8 oz of pag 46 in in compressor. Guess what. There was only around 4. Go figure.
:no2:
Denisefwd93
74
South East PA
If you still have the system open, why not take out the accumulator and dump the oil out, then you'll have a better idea how much is the whole system before you put the new compressor into operation.
Good luck!
Craig0320
225
Mississppi
I replaced this compressor four months ago. The clutch bearing started to fail and I just got the replacement in this week.
Denisefwd93
74
South East PA
Well that kind of stinks! hope you have better luck with this one!
