AgPete139
09/2014 OTOTM Winner
- Aug 12, 2007
- 61
- Houston, TX
- Ford
- Engine Type
- 4.0 V6
- Engine Size
- 4.0L OHV
- 2WD / 4WD
- Solid Axle Swap 4x4
- Total Lift
- ~9"
- Tire Size
- 35"x12.50"x17"
((Will add more pictures IF I find them possibly when I first bought it)
Howdy,
So, I've been here for the last freakin' decade and I've finally decided to make a thread for the RBV (to catalog it, instead of having pictures all on my phone or roaming around the depths of my PC). It's mainly been my DD, and a 5% offroad toy.
BACKSTORY:
I bought a white '97 4.0L 2WD Xcab 82K miles when I was 16, since I hadn't enough money for a low mileage fullsize. I grew to love the compact size and utility, and I eventually did a 2" washer lift, 3" PA body, and threw some 33x12.50x15 ProComp A/T on there along with a K&N, muffler, and explorer seats. I beat it to Hell and back at 200K miles, until 3 years ago when I got T-boned by another driver that wasn't paying attention to her stoplight. It got totaled, bought a nicely used BMW for Dad, and got myself a '92 GT Foxbody convertible.
I longed for another Ranger, and finally found one on Craigslist. I picked this exact one for several reasons...
WHY I BOUGHT THIS ONE:
FRESH PARTS / REPAIRS:
CURRENT PICS as of September 2014
http://img.photobucket.com/albums/v124/big_pete139/Green Ranger II/20130722_201540_zps88046db9.jpg?1410535743428
Check out my wedding cake:
I need better flex pics. And build progress pics. As you can see, I either take a crap ton of pictures of trivial parts, or no pictures at all.
Howdy,
BACKSTORY:
- Extended cab
- '97 had the 2 piston brakes
- '97 had the revised 4.0L design
- '97 last year of the TTB
- 4.0L had the 8.8" rear, larger discs, and larger drums
- Familiar to me, and like the body style better than the Gen I/II
- M5OD-R1
- Already had a small lift and the rivets drilled out!! lol
- Explorer gauge cluster has the tachometer installed
- Body is straight, save for a few offroading dings
- Good head unit (not the best out there, but acceptable)
DRIVETRAIN- 1997 4.0L
- Warn Premium manual hubs / repaired 4WD w/ new axle hardware
- BW1354M t-case swap; custom bushings
- Explorer 8.8" 31-spline disc axle swap (fully rebuilt), SOA conversion
- Nitro Gear 4.88 ratio, front & rear
- Richmond Lock-Rite auto locker replaced the LSD (rear)
- Solid Diff Cover (cleared the 4.88’s, added oil capacity)
- New Hayes HD clutch, throwout bearing, pressure plate
- New O-rings on clutch line to inner slave cylinder (fixed mystery leak)
- New clutch master cylinder & safety switch, installed new pedal covers
- Pennzoil Syncromesh to transmission
- New Timken carrier center bearing
- 15"x10" black Rockcrawler wheels, new lug nuts & studs (the other ones were all x-threaded)
- 35" x 12.50" x 15" BFG KM2's
- Used Shifter & New Hurst palm shifter knob (old was broken; used a temporary 19mm wrench)
- New inner & outer wheel bearings
- New "cold air" filter (didn’t want this, but previous owner already had intake tube, no stock airbox)
- Fixed idle issue / (cleaned MAF, IACV, vacuum lines, Seafoam brake booster & intake)
- Marvel Mystery oiled crankcase / removed sludge, Fuel filter / motor oil
SUSPENSION / BRAKES - Superlift Superrunner Steering (K-link, NO MORE BUMPSTEER!)
- Fixed so much of the suspension, it's not funny
- Newer softer Skyjacker 6" springs (previously tried Trailmaster coils and Bronco/F-150 coils)
- Fixed popping suspension via balljoints, fixed lifted suspension quirks
- New drilled & slotted rotors
- New premium organic disc pads
- New premium organic drum shoes
- New drum hardware & springs & wheel cylinders (on both Ranger & Explorer 8.8”’s)
- Flushed brake system w/ DOT 3 (black fluid!)
- Alignment & misalignment bushings
- Softer Explorer 8.8" leaf springs (previously Skyjacker lift springs)
- Beltech 6400 extended shackles
- James Duff radius arm bushings, TTB axle bushings
- (4) ProComp ES9000 twin-tube nitrogen shocks (23" compressed, 30" extended)
INTERIOR / ELECTRICAL: - New black carpet & extra insulation
- Thoroughly cleaned the cab from previous owner (if you smelled it, you'd understand it was its own mission, months to get rid of the tobacco and dip stench & stains)
- Dynamat entire cabin (for sound & vibration)
- New Pioneer 3-way, 5"x7" speakers
- Pioneer head unit
- 12" Rockford Fosgate P2 woofer in sealed Ranger MDF box, amp, new Monster 8 gauge wiring
- Made 40/40 buckets + seat covers
- Blue interior lights
- Wrapped headliner in black fabric; previously broken headliner got wet and took out a year later
- Typical electrical maintenance items / 850 CW Motorcraft battery
- Uniden 520XL CB Radio, (forgot the 18' brand cable, K-8?)
- Firestick II 4-foot antenna
- CB Radio Amplifier
- In-cabin 0.3 gallon air tank & compressor (for tires, airhorn, compressed air nozzle)
- 120 db metal train horns, mounted under truck bed
- Spray painted interior black
- TRS "bucket" Ranger seats
- Fiberglass center console (thanks to Hazmat)
- Explorer overhead console
- 20% tinting
BODY / OTHER - Performance Accessories 3" body lift
- New tailgate bushings (tailgate was slipping out)
- Banged out (as best as possible) tailgate // fixed locking mechanism
- Fixed A/C, new compressor
- New fog lights (tractor lights from Harbor Freight)
- New Bosche wipers (new set for past 4 years)
- Steering wheel grip (old was faded and crumbling)
- Used fiberglass Lund bed cover & plastic bedliner
- Painted & installed fender flares
- Zip-tie throttle mod
- Aluminum side steps for passengers
- Installed used driver's side power mirror
- TRS Banner mod
- James Duff body mount bushings
- Finish fiberglassing custom center console
- Clear corner marker lights
- Class III hitch
- Replaced leaking windshield & rear sliding window
CURRENTLY (under the knife):- 1978 Bronco Dana 44 HP front axle + radius arms
- Custom brackets, track bar, tie-rod
- Chevy 1-ton TRE's, reemed knuckles for 7/8” bushings
- Solid front diff cover
- Deaver springs
- Skyjacker extended braided brake lines
