Air in clutch system problem!
Dhunter830
2003, 3.0, 2 wheel drive, 5 speed obviously, had to put a slave cylinder in now my clutch dosent engage or disengage until about a inch from being fully depressed. I've read many forums on the problems with air being trapped in the master cylinder and a hundred ways to get it out. What is the best way to get it out? This is my daily drive 80+ miles a day and have alot of stop and go in my route.
Best way I have found is to take the master out, hook it back up and bleed it all while holding it upside down.
Rearanger
23
Southeast USA
You'll also find it a struggle getting to the master to remove it. The inner fender splash cover needs to be removed.
I ended up cutting out a section that I can screw back into place.
