supposedly it gives like a 10hp increase
Not even remotely close. I don't think it would give anything more then 5 if even that.. Nothing you would "feel" anyway..
I'm new to "Ranger" tech, but not new to engines. So some of the following may apply, it may not. I have a Mustang background and I'm new to the 2.3 world but I'd
think some of the same principals would apply..
The purpose of the piece is to quiet the sound of the air rushing into the throttle body. You notice a difference in throttle response due to the smoother more direct flow of incoming air.
Try coating the pipe with a heat paint also or some sort of heat wrap. The metal will retain heat, which will pass along onto the incoming air. Heat kills power and your defeating the purpose of trying to get more power.
Along with this "mod" I'd say throw in a stock replacement K&N air filter if you already don't have one. Avoid switching to an open air conical filter, as it will suck in the hotter air from the engine bay pretty much eliminating any gain.
Also, I don't know if they have them, but removing the "air silencer" on the stock air box, will also free up some air going into the engine. Do a makeshift "Ram air" to the hole where the silencer used to be, and get cool air in there.
Keep in mind, getting more air in, without helping get it out (IE; Exhaust) is defeating the purpose.
