bossbob
- Mar 9, 2017
- 0
- corona, ca
- Ford
I put the pressure tester on it this morning, cold engine was 0 psi. Rocked the key on and off, I could hear the fuel pump cycling and built the psi up to 20. Started the engine and max psi was 25. No fuel coming out of the return line with just the key on.
I reinstalled the old FPR and even though it doesn't hold pressure, it runs at 38 psi at idle.
If I disconnect the vacuum line and plug it the engine runs better and smoother at idle, but didn't test it under load.
Does it still sound like I need to pull the tank.
Either one still runs crappy like it's starving for fuel. At idle the engine is surging, under load it is hesitating.
