The_Epsicle
- Mar 2, 2015
- 2
- State of Boredom (Nebraska)
- Ford
- Engine Size
- 4.0 Pushrod V6
- My credo
- All hail the mighty ziptie!
I did a dumb a few months ago and I just found out about it. I'm in the beginning stages of removing the 4.0 engine on my 1994 Ranger and I had some unexpected trouble with the alternator. When I last attached the nut to hold on the power wire for the alternator (pictures below) the washer must have fallen off unbeknownst to me and since that point they rusted together slightly. The nut was coming off with some difficulty and I noticed I was actually turning the stud that the power wire attatches to. At this point I just cut the wire and figured I'd solder a new connector on later. After I finished tearing apart the engine bay for the day, I noticed the stud was a screw, and I unscrewed it quite a bit. I want to avoid buying a new alternator since this one is going strong so I have some questions.
1. Can I screw this stud back in? If so, what should I torque it too?
2. What gauge is the power wire for the alternator on a 4.0?
3. Does it really matter if I damaged the red thing? As far as I can tell it's just there to let you know there is a lot of power going through that wire.
The stud with the connector and nut attatched
A close up of just the stud, go figure the nut falls off after I cut the wire. you can also see the red thing I damaged when the wire started turning with the stud/nut.
