Aushkoshbgosh
- Apr 6, 2024
- Reaction score
- 14
- Location
- Texas
- Make / Model
- Ford/ ranger
- Manual
I'm fixing up my 88 ranger. 2.3 2wd with almost no mechanical experience at all. What could go wrong.
This truck got me through some hard times and I wanna get it working again. In part for sentimental reasons and in part because I want the know how.
Not asking for help at the moment though later down the line I may need some assistance and so far this forums been a big help. Mostly I'm just documenting progress and keeping notes to myself
As far as I can tell this is the to-do list, what I've already done, and some problems I'm facing.
-Replaced the cylinder head.
This I finished yesterday, took me a while to find a good one Seems like an exact match. Two step Torqued 50 to 90 pounds easy stuff.
Reattach exhaust manifold. Easy I'll get that done this morning
-Rebuild intake manifold and throttle body.
Took the whole thing apart (probably didn't have to but I wanted to check it for damage and clean it. Had a bunch of carbon on it and I was worried it might be a problem. Far as I can tell it's just oil that leaked from the head.
-Timing belt.
Yea so, yesterday I realized there are no timing marks on the inner belt shroud, my new head or aux sprocket, and no clear ways to adjust it not gonna worry about that for now I got it tdc the head was exposed anyway so it wasn't hard but I'm reading up on how to set the timing marks I'm sure that'a gonna be fun. For now I got it on and in place
-Check power steering.
I got a leak somewhere and since I got it off and taken apart I might as well see if I can spot where it is.
-Attach the fuel line
(check for damage and make sure it's fully attached to the front tank at least.
The rear tank hasn't worked since I bought the vehicle but I'm not worried about that. I also need to fix/replace the sender for the fuel indicator of I can
-Replace damaged fuel hoses
under the first tank and between the filter and throttle. The hoses were pretty dry two of them cracked when I was pulling it off. Wooh
I want to See if I can repair rear tank to (not essential)
But I'd like to see if it's rusted through it if it's just poorly connect
-Attach distributor cap then sparkplug wires and plugs, vacuums easy stuff I hope
-Rebuild the pulley system
water pump ac and all that, Ive had to replace the belts before this probably isnt an issue
I also replaced the alternator and negative battery cable a while back Those seemed to be working (though if I'm being honest I did a sort of slapdash job with the alternator) I'm just bringing it up in case it's it helps diagnose problems later on down the line
And uh.. put the radiator back in. Coolant system needs to be flushed... Also I should change the oil check the breaks
Refill power steering (I replaced the pump it was screeching like a bat)
Probably need to check the breaks
After all that if I get it running I'm gonna buy it some new tires and get the alignment checked for my victory lap.
-Timing belt.
