trailbikerider
- Jun 18, 2010
- 0
- Kalamazoo, MI
- Engine Size
- 4.0L
On my 94 2WD, every time I go over any moderately sized bump when it's cold outside (say below 20°F), I get a bad clunking noise coming from the front end. My steering wheel also shakes vertically more than it should pretty much every time I go over any bump no matter what the ambient temperature outside is.
I've read the steering wheel shake may be caused from air in the power steering system? But I have bled the PS system probably 5 times with no improvement. So I'm thinking they both are related to the same problem and I was thinking maybe the R.A.Bs? The only problem is my truck doesn't have the normal symptoms of a bad radius arm bushing; like clunking when switching from reverse to forward or clunking when hitting the brakes.
It's had this problem for probably over a year now and it's just starting to get to the point where it's bothering me and I want to have it fixed. Other than the RABs, any other suggestions as to what it might be?
