Any ideas on Disc brake conversion?
Andres629
11
Saskatchewan!
2.9 screamer
On an 8.8? But not just any 8.8... a full-width 8.8, oh yeah! I want to try and make it a mostly factory swap so that I don't have to surf the information super-highway to get parts when something breaks... So far, I've got it narrowed down to an Explorer setup (allows me to run 15" rims) with a re-drilled rotor and the axle flanges machined down to fit in an Explorer disk's hat. Anyone have any other ideas, or see any flaws in my plan thus far? Thanks!
Andres629
11
Saskatchewan!
2.9 screamer
...no one with any feedback?
snoranger
Professional money waster
ASE Certified Tech
13,742
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
You've got a solid plan there, do it. Most other setups force you to run a 16" wheel or custom rotors (as opposed to modified off the shelf rotors).
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
From what I know, I don't see any flaws with it, as long as the backing plate pattern is the same. You might need to machine the rotor's center hole larger to fit over the axle's centering hub, but not sure.
snoranger
ASE Certified Tech
13,742
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
The housing ends are the same between the Explorer 8.8 and the full size. So same bolt pattern.
I would go the other way if possible (and if needed), machine the hub not the rotor. This way if you ever have to replace the rotor down the road, it only needs to be drilled to the right bolt pattern.
Andres629
11
Saskatchewan!
2.9 screamer
Alright, well thanks for the positive feedback. Basically I was posting this to find out if there were any inherent drawbacks to this plan that I somehow overlooked. I'll take lots of pictures when I do it!
snoranger
ASE Certified Tech
13,742
Jackson, NJ
'79,'94,'02,'23
All Fords
2.3 EcoBoost
The only problem I see. Is the axle flange (wheel mounting surface) the same distance from the housing end on both axles?
4x4junkie
584
So. Calif (SFV)
Bronco II
2.9L V6
35x12.50R15
Good idea :icon_thumby:
Andres629
11
Saskatchewan!
2.9 screamer
Hmm, valid point snoranger. Got me some measuring to do! :icon_thumby:
