anyone know much about a coleman powermate air compressor
91stranger
512
Gets Mo Chicks
So I bought this for a good price and I have been needing a medium size air compressor. I already have a craftsmen pancake compressor that I use a lot and wanted something a tad bigger but still portable. Found this coleman powermate handyman 4 hp 11 gallon air compressor. I got it and it works good but it does not show what the flow rate is for air tools. I cannot for the life of me find anything online. I am wanting to use this for basic tire pumping and if it could run an air impact that could break lug nuts loose then that would be great too.anyone know much about these compressors, if they are good? what they can be used for? what they are rated for? Here are the pictures of the only tags on here but they don't give much information. Please help me figure out what this is capable of. I don't want to buy a bunch of air tools for nothing.
97RangerXLT
TRS 25th Anniversary
3,960
Fishers, IN
2"
31"
That will be just fine for airing up your tires and using small air tools. I would not expect it to be able to run a 1/2 impact gun tho...
AJ
You might break lug nuts loose with that thing, but I wouldn't trust it to put them back on.
It is rated for a max PSI of 135. Most shops are running unregulated air upwards of 175 PSI, so your tools will be quite anemic.
I don't know the specs on it, but an 11 gallon tank, you are probably flowing a MAX of around 5 CFM at 90 PSI. Most common tools are between 4 and 6, but like I said the more pressure the more power. More pressure also means more air coming out, so less keeping up.
scotts90ranger
4,401
Dayton Oregon
2.3 Turbo
For tires I wouldn't worry about it too much, don't expect it to run a die grinder at full blast or a 3" cutoff saw or a sander, but for normal household stuff that will be fine, I'd expect it to be fine for tires and what you are talking about. Air tools are rated at 90psi, I run my 145psi compressor wide open which helps with the lug nuts... For tires, expect the compressor to run constantly basically, it'll most likely keep up
alwaysFlOoReD
5,118
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
You have almost all the info you need to figure out exactly what this unit flows. Empty the tank and then time it from start to cut-off. A little google-fu and you can convert 11 gallons into cubic feet. Then it's just a matter of manipulating the numbers until you get
CFM; Cubic Feet per Minute
The CFM will be at 135 psi. Most CFM is posted at either 90 psi or 40 psi. If you can control your cut-off pressure to 90 psi then you will have a number that is easy to compare to other compressors [I don't think this is possible without changing your regulator]. There is probably a formula to convert from 135 psi to 90 psi out there that will give you the same info.
scotts90ranger
4,401
Dayton Oregon
2.3 Turbo
CFM is just a number that I wouldn't worry about too much on low air usage tools. Sanders and grinders are high usage tools that I have had no luck using on even my 20 gallon compressor, throw in air hammer too to some extent, don't expect that to cut through frame rivets like some people talk about doing... For lug nuts an impact is actually a fairly low air usage tool, you have 10 seconds max of high power requirement followed by a very light load, at worst you will have to wait for the compressor to cycle to break the next lug nut loose from my experience...
From a calculation standpoint timing it from 0 to 90psi is not the same as CFM at 90psi, the rating is CFM at 90psi is very different and not very calculateable for the average person... but it also doesn't matter as much as you would expect...
91stranger
512
Gets Mo Chicks
ok sounds good to me. I actually have a 3/8" and a 1/2" impact and it seems to run those good at free spin. I haven't had a chance to try to break a lug nut loose. I don't ever use an impact to tighten lug nuts, don't trust them. I always use either a torque wrench or just my 18" breaker bar. I used to change tires all day everyday for 2 years so I have a pretty good natural feel of what 100 pounds feels like on a torque wrench. So I swapped the air hose for the orange coiled air hose from harbor freight. seemed like the 3/8" 50' hose what restricting air flow. that orange coiled hose helped a lot. so far, I like it. I just needed something slightly bigger than my pancake compressor. I figured since this has a 4 hp motor and 135 psi it should be pretty capable besides having the larger tank. wish I could find a manual for this though.
Ranger850
Doesn't get Sarcasm . . .
4,691
Tallahassee Florida
Stock 2"
Stock
Mine is not a Coleman but this is a sticker that is on the motor. Is this what you're looking for? :icon_confused:Sorry it's kinda worn.
ColemanCompressor
Washington
Mazda b2600i
Hello I'm looking for these answers too
How is it working have you used it used the air ratchets that is? What about the impact? I recently got the same compressor as you and and am wanting it mainly for blowing carbs out, air gun and a ratchet and maybe an impact . Just to break some nuts and bolts lose on mini bikes
91stranger
512
Gets Mo Chicks
I still have it. It works good for impacts but the tank doesn't last long with an impact. I have battery stuff so I mainly use it for tires or cut off wheel. It's reliable. Kinda loud though but it is a 4 hp motor. I got a silver bullet oil air compressor I've been fixing up lately.
ColemanCompressor
Washington
Mazda b2600i
So could I efficiently run a ratchet and impact? Not constantly but here and there I'm also potentially making a aux tank here soon that will add 6 gal..
scotts90ranger
4,401
Dayton Oregon
2.3 Turbo
For what you are talking about, you should be fine, long running of a ratchet will get weak and you might have to wait for it to cycle between some lugnuts but it's workable if you have patience. I use my 2.5hp oiled 20 gallon compressor for stuff it's not great for...
