Jim Oaks
Just some guy with a website
Administrator
Founder / Site Owner
Supporting Vendor
TRS 25th Anniversary
- Aug 2, 2000
- Reaction score
- 8,842
- Location
- Nocona, Texas
- Make / Model
- Ford Ranger
- Engine Type
- 4.0 V6
- Engine Size
- 4.0 / 2.3 Ecoboost
- Automatic
- 2WD / 4WD
- 4WD
- Total Lift
- 6-inches
- Tire Size
- 33x12.50x15
I've been re-educating myself on this today. So I guess if you bolt it in to the stock location, then ideally you want the Dana44HD passenger shaft which is shorter, and you still need to cut about 3/4" off of it.
If you did get it mounted, then you'd have to contend with the steering linkage and steering box.
I feel like it would be easier to get a 2000+ Ranger, and swap it on to a '95-'97 Ranger 4x4 frame with the D35 already in the front. Then maybe go D44 hubs.
We've discussed this on here before, but I don't think anyone here has tried, but the '95-'96 Bronco/F150 5-bolt D44 spindle will bolt to the Dana 35 knuckle. I learned about this years ago at a desert race in Nevada.
You can get the spindles new for $175.00:
https://shop.broncograveyard.com/D44-OE-Spicer-Spindle-1993-95-NON-ABS/productinfo/32083/
According to a thread on dezert rangers, The issue is with the caliper and pads fitting over the D44 rotor. You have to have the rotor machined down from 11 3/4" OD to 11" OD.
Someone mentioned that:
This is something that I think needs explored more.(For the 95+ trucks *i think) the calipers/pads not having a wide enough gap to accept the rotor, the bosch caliper that autozone sells, its pistons were recessed a whole lot more than my oem calipers, i was able to use a brand new unmodified rotor, with almost new pads, no problem.
