Anyone tried to buy D35 gears lately?
Uncle Gump
Token Old Guy
13,467
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
And now you know the rest of the story...
As far as members being critical or thinking they know everything and that choice of another member is stupid. Spare us all... and just keep that negativity bottled up. Nobody cares to hear it.
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
inner 27 splines....outer spindle bearings are certainly a weakness ... when exceeding 35's. no matter the engine.
going to a 513 adds pinion failure to that list..
my engine is a high rpm diesel as well. if you are n/a i can see why you would consider this. if you are running a turbo...then 456 gears look much better all around to me...even 410 gears.....depending on transmission.
n/a with a 6.2 diesel and 37 inch military tires cruises me 75 mph comfortably with a 4l80 transmission. usually i have to drop back to drive and run it on the governor.....
Northidahotrailblazer
457
Northern Idaho
Solid Axle Swap 4x4
8 inches
37"
you have almost 30 more hp and like 40 more torque and you have 3 more cylinders to help. I’m going with what the countless Toyota and Jeep guys say. And my experience also. I had 410s and 35s with ford 4.0 and after going with 513s. I would never do anything less for a 35 and bigger tire. I wish I would have went with 538s in my ranger. But that’s my real world experience. People don’t gear down when they need to and they get use to the shitty performance and idk just deal with it. I know I was one of them. I was only going to go with the d35 because I could regear it and throw a lunch box locker in it and run for the summer but since Covid killed 513s for TTB d35s it looks like I’m gonna have to get creative on what I do.
17,853
SW Iowa
Sadly Covid did that to a lot of older, slower moving but still moving things.
A guy can't even get a new spindle for a D35 anymore.
On that note, D44 spindles can be swapped on, may be worth a gander if you are going to run 37's to get better wheel bearing spacing and better lockout hubs. I only have 31's, the only thing holding me back is screwing with my wheel bolt pattern.
457
Northern Idaho
Solid Axle Swap 4x4
8 inches
37"
Quick performance got back to me this morning they claim to have D35, reverse cut gears. The guy was aware of the difference. So I’m going to call tomorrow and order them!
bobbywalter
TRS Technical Staff
Ugly Truck of Month
4,668
woodhaven mi
FORD mostly
BIGGER
sawzall?
My truck weighs over 6k at cruise weight. So...keep that I mind. That 30hp....isn't enough.
Did you have the limiter raised on the 4.0?
I was taking this as a daily driver jack of all trades rig with maximum fuel economy as the goal...so maybe I am way off...
If driving on the road is the main goal...one really needs to be careful. But since you have done both the 410 and 513 with the same setup then your preferred is an exact known. So that is awesome for baseline.
Under gearing is a constant....most won't deny that.
I have gone too far with gears a few times and lived by the deeper the better for a long time .
I have this same conundrum with my bronco. For cruising ... the 410 gears are almost too low with 33 inch tires. Fine with 35 or 36s.
But 70 mph is about as fast as it needs to go anyway so it's more then livable.
I went with the 33,s for road tires as i still had 410s
getting the snow rating on pavement in a 35in 15 rim for street duty was a 400 dollar difference... with a much lower run life.... So I was happy to settle on 33 for my spare driver.
I was glad we did not get to putting the 488s in it .. or I would have been screwed. Need that cash for the t56...
Of course ..
Off road those gears are way too high with 36 inch tires...making me wish for 513s when in moab.....but a doubler will correct that. For the money a doubler makes more sense.
I had 488 gears with a 300 plus hp in my ranger for some time... Even on 37s, they were way too low for hi-way driving...on 33s it was hell .
33s are cheap when your wasting rubber daily driving freeway.....not as cheap as military 37s....but military tires suck in the snow.
...and that was with an aod.. 456 gears were also too low...but better as long as I had 35,s. I would be married to 37s in my ranger if I had 456 gears.
Can you drive a vehicle equipped with that 5 cyl engine? Any of those you have talked with online close enough to go check it out? I know it was real popular in the mid 2000s in my area....mostly jeeps and old landrovers.
I still think 456 gears will allow the most usability....unless your gonna run heavy like me....and if that is the case.... probably want more engine anyways.
I know I am looking forward to seeing it going down the road.
00t444e
217
Southern OH
Ranger ext cab
Because I do and why do I need to explain it to you? I never asked what a D35 could handle. Or anything other than if anyone knew if d35 513 gears are available….. since you must give your .02 cents hear is why I need 513 gears. Because I’m running a OM617 5 cylinder diesel…..this diesel is not like other diesels. Its torque comes on at above 3k in rpm. Like more like around 35k. For big tires I need to go with deep gears. I really should go with a 538. But anyways plenty of people have had luck with 513s and 35s.
No different than the 4.0 then, and the 4.0 works great with 35" tires and 4.56 gears.
