Anything to know about a '11 Escape V6?
rusty ol ranger
2.9 Mafia-Don
7,502
Michigan
177 CID
My eldest daughter has been trying to kill her '11 Escape for past 30 months...quite unsuccessfully
The rust on @rusty ol ranger 's Escape is minor compared to what is on her's. For some reason, the '08-12 were terrible for rust over rear arches/tailgate. The older '01-07 seems to do much better.
I hate the automatic - never seems to be in right gear in city. The traction control is annoying too - I'm 2 or 3 steps ahead of it.
Repairs on her's in last couple years:
Passenger's front window 2X due to thieves in her parking garage.​
Throttle by wire body. Was a long drive 30km/h from her work to my place to get it fixed​
Starter motor​
The boot on her driver's half shaft has been torn for at least 3 years. But CV won't fail (She has replacement shaft but is too lazy to get it installed).​
Transmission leaks but she just tops it up (drives me nuts as I hate oily driveway)​
Hinges on rear glass corroded and failed.​
Overall, everything that broke has been as easy to fix as my Ranger.
There are Gen IIs with 2.3 Duratec and 5spd manual, but they're as rare as that 8 bolt 8.8. And they're definitely AWD, not 4WD, with automatic - stuck with one wheel spinning was...embarrassing.
wifes was a 2010. Had a 2.5/6sp auto with FWD. It had no balls whatsoever...but was reliable as the sun and got around 28mpg.
The traction control on it was a joke. Numerous times id be "stuck" in 3 inches of snow because the system went so crazy it basically shut down the vehicle. Id shut it off, stand on it, see saw the wheels and out she'd come
scotts90ranger
4,372
Dayton Oregon
2.3 Turbo
The only real issue so far is when cold the transmission will flare some shifting into I think 3rd gear but then shifts solid... he has enough fluid to do 3 drain and fills so hoping that might help some but he apparently looked and the bypass valve in the pump I guess has some wear issues that Sonnax makes a new valve for it but that's a lot of work to get to the pump... Since it shifts solid especially once warmed up (after about 2 miles it shifts fine) hopefully it will last til next winter, we'll see...
racsan
4,443
central ohio
ford/escape
2.5 (4 Cylinder)
2.5/151 I-4
the grey-t escape
The first thing I do is shut off the traction control as soon as I start it, if there was a fuse for it alone Id pull it and never look back. Were almost to 180K on it, sometimes it seems like it takes a while to get to top gear if its being drove hard (me lol) she doesn’t have that issue. Ive got some sort of a oil leak up front, doesnt amount to much but the evidence is on the garage floor. At first I thought it was coolant but nope- its oil. Only down a qt at 4,000 miles so not horrible and some of that could be normal blowby at this milage.
Roert42
4,961
Kintersville, PA
Ranger XLT
4.0 SOHC
I like to put my automatics in Neutral when I'm idling to let the engine warm up. Lets the fluid circulate and com up to temp too. I find that helps eliminate the hard shifting on a cold transmission.
