auto to manual trans swap trouble
nossbud
FORD
so i bought a 94 ranger 4x4 4.0 and the guy before me swapped the auto trans out and put in a manual. i can shift into 4 high but no 4 low. the gauge pod says its in park and thats where its been since i got the truck so im wondering if i where to shift that into neutral from the colum if it would let me shift into 4 lo?????? not sure if theres some sensor or if im out of my mind.
99RangerKrazy
Kennewick, WA
Are you trying it with the manual tranny in neutral?
nossbud
FORD
yes with the manual in neutral but it still has the automatic steering colum in it. so im wondering if i shift it into neutral on the colum if it would work??
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
Are you pushing the clutch in?
dogboy
14
Enumclaw/ Carbonado, WA
'93
The column has nothing to do with the shifting of the t-case. I still have my auto column in my truck, and all I did was take the shifter off, replace the column covers with the manual column covers, and put the blank coverplate over the gear indicator on the dash.
That being said, you must have the tranny is neutral (as far as I know) and the clutch depressed, in order for it to go into 4low. Unless the guy never worked on the clutch pedal, in which case the truck thinks the the clutch is always depressed, and it will even start with the clutch out, in gear (like mine).
I think you're problem is electrical. I can't remember what I did, but when I did my swap, I had a problem identical to yours, it would go into 4wd fine, but no 4 low. It was a wiring issue under the truck. I don't recall what exactly I did, but I know I got a wiring diagram of both the transmission circuit, as well as the 4wd circuit, and once I did that and figured out what made sense going where, it all worked fine.
If I'm not mistaken, there are 3 "sensors" on the t-case computer. A speed sensor, a Clutch sensor, and a neutral safety switch (I'm not sure about the last one, but I think it is). If the truck starts, then the clutch sensor works, it is just a matter of making sure it is connected to the t-case/ t-case computer.
I hope that helps at least a little.
nossbud
FORD
dogboy-did or do you have any reverse lights at all because mine are on solid all the time so i just unpluged the bulbs. i do kno that there is a sensor on the top of the transmission that doesnt have a plug going in it. also theres like the end of a wiring harness up towards the top of my bell housing that has wires spliced??? not sure whats going on there?? and my clutch is like yours
mjonesjr
I dance with the Devil...
Firefighter
Forum Staff - Retired
13
Salem, IN
Your best bet would be to find a truck just like yours that came factory with a manual transmission and get the transmission wiring harness. It unplugs right behind the engine block. Swap those harness out and everything will work perfectly (back up lights, 4wd, etc.).
Once you get the harness swapped, you will have to have the clutch depressed to switch into 4 low. There is no sensors on the transmission telling the PCM that it is in neutral, so that doesn't matter. As long as the clutch is depressed, then it will shift into 4 low. The PCM gets the signal from the CPP (Clutch Pedal Position) switch that it is depressed.
Earl43P
38
Farmington, Pa
Ford F250 4WD
If you need schematics, shoot me a PM with your e-mail address.
Maurice is correct, you should do it correctly and install that harness, install and connect the clutch pedal switch, and the reverse light switch.
