Run a E4OD under heavy load day in and day out, and run a T18 under the same conditions, gurantee that E4OD will puke.
The T18 was designed for trucks up to 2.5tons. The E4OD seen max duty in the F350 (maybe the F450, not sure), no where near the duty the T18 seen.
What is the biggest killer of all automatic tranmissions? HEAT.
With a manual transmission, heat is not really an issue, of course there is heat, but since everything should be completly locked to togther all the time (with the exception of taking off and shifting) heat should be kept to a minimum. Not to metion that a stick shift isnt as sensitive to fluid levels as an automatic, so when the fluid does get hot in a manual and expand it isnt confusing itself, shifting back and fourth, back and fourth, creating heat, which will ultimiatly kill an automatic.
Also, with a automatic its harder to detect when your working the tranny to hard. Atleast a manual gives some warning (it whines, or becomes hard to shift) before it takes a dump, normally an automatic will start slipping and a mile down the road you'll be walking.
They dont call them slushboxes for nothing.
later,
Dustin
