B2 2.9 build
Countryboy91
Zanesville, Ohio
2.9 stocker
Ok so I found a performance shop near me thats willing to build me a one off intake manifold to put a fitech self tune throttle body on. Was curious if any ha ever gone done this road? Also would like suggestions on roller rockers trying to build either small tt 2.9 or single turbo 2.9. This bronco sees mud and is a daily driver. Any help be grateful
bronco2fan
10
Copperas Cove, TX.
2.8 V6
2.8
3 inch body lift
I can't be much help with this as I haven't seen it done before. You may get more help if you post this in the turbo section I'm guessing. Good luck.
Countryboy91
Zanesville, Ohio
2.9 stocker
Thanks bronco2fan. The turbo idea just kinda floating. But was curious if and one ever successfully made a 2.9 carbureted etc...
BlackBII
Ranger Custom
Truck of Month
982
UT
There's some info here:
http://therangerstation.com/tech_library/Kunz_Korner.shtml
If you build a custom intake manifold, you could add a carburetor sure. The question is why? It's not going to move any more air.
A common suggestion around here is to do a 4.0 swap; the 4.0 from an Explorer/Ranger is an easy bolt in swap.
Josh P
50
Phoenix, AZ
How much power are you looking to make? What are your goals?
