Back Window Leak
SuperRob
Victoria BC
2.9
Ok guys....as usual, I have a problem...
I attribute my constant run of problems to the fact that I drive an old Ford. But I will deal with these problems one at a time and continue to drive my old Ford because I wouldnt drive anything else!
But here's the latest one.
My back window is leaking. I know the usual deal is remove the interior panels, undo the nuts that hold it in, and gently push the window out....no problem.
Well, thats a lie. Problem. The nuts are seized to the studs in some cases and I cant get them to come out. The studs are just turning in the window molding. Soooooo.....What can I do to get the window out, and if I have to grind the studs off are there replacements available? Or do I have to get a new window?
Oh, I forgot, a new window is NOT an option because then I'd have to get new TRS stickers....and I'm broke. So in that case I think I'd just silicone the piss out of it and put the window back in, and then strap it tight with a piece of plywood while the silicone set.
Whatcha'all think?
Help please!
SuperRob
Victoria BC
2.9
figured it out.....ended up cutting one nut off with a zip cut, but all the others came after mucho penetrating oil.
codered1300
Did you check your third brake light? My son has a 99 ranger and he siliconed up his rear window because of leak, and when i finally got a chance to look at it, i noticed his third brake light was loose and water was running down it into the cab, making it look like a back window leak. hope this helps, its easier than a back window removal.
Jspafford
Logan Andrew Feb 17, 2012
15
Lancaster, Ohio
Chevy 3500HD
6.6L
5"
Yep, my brake light has leaked on both my rangers.
sdlucky7
Santa Barbara, Ca
Same here...
