Bad shake at highway speed
L321
Mazda
I have a 2009 B4000 4wd that has a bad shake/vibration at highway speeds. It will shake the truck and can really see and feel it in the steering wheel. This has done this every since I got the truck years ago. Since I have had the truck I have had new brakes, new, shocks, new tires, new wheels, new universal joints, new ball joints, new wheel bearings, removed the front axle, tire balance and alignments and nothing has helped. The tire wear is fine and drives straight but with a bad shake. It also seems to be worse the warmer the weather gets.
Does anyone have any idea what could be causing this?
Thanks!
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
6” skyjacker 2” body
33x12.5
Driveshaft bent or out of balance. Bad or improperly installed ujoint. Seems you’ve replaced most everything else.
Uncle Gump
Token Old Guy
TRS 25th Anniversary
13,619
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
You may have a bent wheel... or two.
55trucker
183
Oshawa, Ontario
mild
A the time you did the brakes were the rotors also replaced?
L321
Mazda
I have thought about the driveshaft. Even used ones are $600+ and haven't found a place that balances them around me. The driveshaft is fairly rusted/flaky. I would gladly pay whatever the cost is for a driveshaft, but would hate to pay that much and it not help anything.
L321
Mazda
L321
Mazda
55trucker
183
Oshawa, Ontario
mild
Try putting all 4 corners up on stands as close to the wheels as possible and get the drivetrain going, spin it up to the speed where you begin to feel the vibration, basically attempting to duplicate the issue motionless.
L321
Mazda
I will try that, but will need to pick up another pair of jack stands first.
Uncle Gump
Token Old Guy
13,619
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
Can you drive a bit faster and the vibration goes away?
Typical sign of a balance issue.
Also have you tried rotation of tires to see if it moves?
L321
Mazda
Vibration gets worse if go faster. Have rotated tires and doesn't change. Have had tires rotated and balanced with old wheels and tires, old wheels and new tires, and new wheels and new tires and doesn't change.
tw205
Bronco II Rancher.
986
Bronson Michigan
Ford Bronco II
2.8 V6
2.8
33x12.5
Check that your driveshaft U joints are indexed correctly.
L321
Mazda
Just checked and can get a used driveshaft from a Ranger for around $100 and would be willing to give that a try. I am assuming it's the exact same? I have found that a lot, can by the same part with the Ford name on it for a lot less than a Mazda labelled part.
Uncle Gump
Token Old Guy
13,619
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I believe the driveshaft will inerchange. There really isn't much left beside the driveshaft.
But remember... that a driveshaft will vibrate at a different frequency the a wheel/tire. So you have to ask yourself... does it vibrate a wheel speed or driveshaft speed?
L321
Mazda
It is a steady shake, but not at a really high frequency like I would expect from a driveshaft. The fact that it doesn't seem as bad in cold weather makes me wonder if there is a rubber bushing or something similar wore out somewhere.
