Battery Light at High RPM
Uhlenhopp09
So as title says when the truck is ~3500 with it in gear, maybe 4000 in neutral, my battery light will flicker softly and then shine bright if rpm goes slightly higher. I thought maybe because it's been in the teens for temperature lately so maybe the belt was slipping on alternator. Put pipe on on alternator and revved up till light came on and heard nothing. Put volt meter on battery and 14.4 while idle and then when revved to light coming on it drops to ~12. It does appear to have an external voltage regulator.
99 Ranger 2.5
Also side question, what "dummy lights" are all in the cluster. More specific a shift light. Some of my lights are burnt out.
3,614
The alternator is weak and can't keep up with the demands of high RPM. Replace it. Any time voltage is OK at idle but goes down as RPM goes up you need a new alternator.
No shift light. My daddy says real men don't need one anyway.
That's not a jab, he actually told my uncle that once.
8,374
It could also be producing too much voltage at high RPMs, battery light will come on for over-voltage as well as under-voltage.
You need a volt meter
Test battery voltage engine off
12.3v to 13v is expected depending on age of battery, below 12.2v is time to shop for new battery
Start engine
13.9v to 14.9v is expected just after starting engine, this is "recharge" voltage, voltage regulator in the alternator is recharging battery after it was drained by starter motor.
After a few minutes of running voltage will go down to "maintenance" voltage
13.5v to 14v, approx. 1volt above battery voltage with engine off, this maintains battery without over-charging it, over-charging shortens battery life.
Increase RPMs to 2,000 and maintain that RPM
Voltage should go up briefly with RPMs then drop back to what it was, that is the voltage regulator keeping alternator from over-charging battery.
If voltage rises with RPMs and doesn't come back down then voltage regulator has gone bad, it will "burn out" the battery if left that way, so you will need new battery along with new alternator if you don't fix alternator.
You can just replace the voltage regulator inside the alternator, fairly straight forward if you are mechanically inclined, BUT(big but) voltage regulators don't tend to fail until the alternator is fairly old, and that also means the bearings, the brushes, and the fields in the alternator are old as well..............you may get another 6months with new regulator or a few years, no crystal ball here, just a heads up.
At idle turn on all the lights and heater fan to high
Voltage should drop and then come back up to what it was before, that is the voltage regulator increasing alternator output to match extra voltage load.
If voltage comes back up but not to what it was before then 1 Field(of the 3) in the alternator has failed, not a big deal but if a second fails then you will need a new alternator fairly soon as you will be draining battery at RPMs below 1,500
3,614
All of that may be true, but he said that Vbatt is dropping near 12V when the light comes on at high RPM.
4x4junkie
584
So. Calif (SFV)
2.9L V6
35x12.50R15
And a battery less than 12.2 volts could just simply need to be charged (this is quite possible since the alt has been malfunctioning).
My suspicion here is the alternator brushes (a wear item) have seen their last day. Replacement brushes are pretty cheap (less than $20 if I recall right).
