Bellhousing Bolt Size?
Freshmeat
40
Denham Springs, LA
I've had my 3.0 Vulcan motor sitting on the garage floor for about three years. Finally pulled it out to put it on the stand but can't find the bellhousing bolts. With a hurricane on its way I'd rather get it off the floor tonight just in case it does flood in my garage.
Anyone know the bellhousing bolt size for these things?
Mine is a '94 with M5OD if that helps.
locovaca
4
DeWitt, IA
M12 I believe, possibly 60 or 65mm long.
Freshmeat
40
Denham Springs, LA
M12 is only one aspect of it. Need diameter, thread, and length.
It's M12 - 1.75 x 60mm, if anyone else tracks down this thread needing the bolt specifics.
ncolton
Thanks for the info. My truck has two different size bolts for the bell housing. Any idea what the other size is? Thanks again.
ratdude747
22
Madison, IN
215/70R15
IIRC it's one size on mine; but the upper 4 bolts thread into the bellhousing while the lower two thread into the block. Length is irrelevant in the OP's case as for en engine stand they'll need to matched to the stand, not the bellhousing.
