Bench Bleeding a Master Clutch Cylinder
bernerboy
Michigan
1988
Both are 2.9
Evening guys
Call me a dummy, but for the life of me I can't seem to get the Master Clutch Cylinder bench bled.
I brought this 88 Bronco II that the previouse owner couldn't get the new slave cylinder bled.
This vehicle has the 2.9 is a 4 X 4 with the FM145 trans and onlyl has 92 k listed on the odometer
Started to bled the supposely new slave cylinder and found out the dummy used Tranny fluid instead of Brake Fluid. Needless to say, I have replace the slave cylinder and brought a new hydraulic line and new master clutch
cylinder.
New slave is install and now I am working on the Master. I have never done one of these before I am not young (55) and the old systems I worked on as a young man are not like these newer ones. I am from the days of the old mechanical clutch systems
I have read everything I can find in Ranger station but can't find anything on Bench Bleeding the Master Clutch cylinder.
Any help would be greatly appreciated.
Thanks from the Dummy in Michigan
Gene
fastpakr
2,841
Roanoke, VA
Unbolt it from the firewall and point it so the angled section at the bottom is low (it makes sense if you look at it - there's a raised section that traps air sometimes), then run a bleed line from the slave into the reservoir. Cycle the piston until the bleed line purges the air the came out of the master, then close the valve and bolt it all back together.
Your problem is not uncommon - if air gets trapped there, all the traditional bleeding in the world won't get it out. Inverting it solves it in moments.
bernerboy
Michigan
1988
Both are 2.9
Thanks for the advise. I don't have it mounted back in the vehicle yet. I have the res and the master on the table and when I fill with fluid, it dribbles out the hydraulic line connecting point. I don't see how you can plug the hole as the roll pin holes are also there. I pump the cylinder and can see air come out with fluid but once I release the push rod, it has to be sucking air back in.
Do I just let it gravity feed.
I have never done this before.
Gene
fastpakr
2,841
Roanoke, VA
Just take it to the truck and connect the hydraulic line, then bleed it from there. No need to bench bleed it like you're doing.
rboyer
4.hoe
This is one of those problems that usually causes people to replace things that they don't need. You wouldn't believe how many times I have sold someone a M5OD and had them come back and tell me the trans is bad because "it won't go into gear unless the engine is off and shifts hard". Every single time I get that I give them advice on bleeding it and then get a reply along the lines of "it worked, thank you". I can't believe that someone wouldn't have come up with a revised/aftermarket master cylinder by now which was engineered to solve the "gravity problem".
bernerboy
Michigan
1988
Both are 2.9
Thanks for all the assistance
Ok it is all said and done and the truck moves and shift with no problem with the tranny.
I got out of bed this morning and said to hell with it and connect the hydraulic line to the master clutch cylinder and bench bled it. Took 3 people but we got it done. Someone said it would feel like pushing on a steel bar and at that point it was bled. They were right.
Took everything out to the truck and installed it. Biggest pain was wiggling the hydraulic line back down to the tranny.
Next was bleeding the slave. I think I used a little of everybody's idea on bleeding. I did take my time and with the help of the little women and the 13 yo boy (keeping the res full) we got the whole system bled in about an hour total time.
This was my first attempt at doing something like this so I am a little geek that it is running again. Now onto the other little problems like the passenger window stuck down (power windows), the auto 4 X 4 has no power. these problems I think I can handle as I have the ranger with the same setup but has an automatic tranny. Going to use the Ranger for any parts
Thanks again for all the assistance and advise
Gene Robinson
Michigan
