Best way to tackle a clutch job
Terry
19
Gardnerville, Nevada
I am going to need to replace my flywheel soon. I am going to clean up the transmission, transfer case and fix oil leaks while I am doing this job. What is the best way to handle this job: 1 Pull motor and trans together. 2 Pull trans and transfer case than lift up motor to change the pan gasket.
8,372
Depends on your shop setup, and helpers available
Dropping trans and transfer case together or separate is not all that hard to do alone.
Then lifting motor out or just up is probably best, in my opinion.
If you have extra hands to guide engine/trans out and then back in it can be easier to disassemble and reassemble
enjr44
9
Renton, WA
02 2X4; 08 FX4
4.0 SOHC
IMHO, anytime you can leave the engine in there is a good time.
Terry
19
I pulled the transfer case, trans and motor. New flywheel and bolts on the way, got a slave cylinder off of ebay "Dorman". New motor mounts. I am going to order the clutch and pressure plate. Pulled the oil pan Will clean the strainer. No need to change the oil pump, it runs at 20 psi and idle. replace the pan gasket and rear seal. Got a set of headers so I got an 88 ecm and am removing all the egr circuit. Now I am cleaning everything. I wished I weighed it before I started. I have removed a ton of dirt, oil, salt and grease. I have a coating like por I got at summit for the surfaces.
Terry
19
Got the seals all replaced on the transfer case and cleaned it all up. Cleaned up the oil pan. I have the gasket kit for the transmission and I am in the process of cleaning up.
Parts list so far,
Exedy Clutch kit 110.00
Dorman Slave cylinder 52.62
Flywheel Rinopac 59.40
Flywheel bolts 4.99.
I bought some 2.9 headers amd an 88 ecm to remove the egr.
I have already ported the intake and heads to match. But this is another story.
Slammin Sam
4
Western Colorado
I assume you are changing the trans lube during this process. If so, be sure you use a lube rated GL-4, NOT GL-5 A GL-5 fluid can damage the brass syncro rings.
Its getting harder to find non-GL-5 lube. Amsoil makes a great synthetic. Its pricey, about $16.00 a quart. It's Amsoil Synthetic Manual Transmission and Transaxle Gear Lube 75W90.
Terry
19
Well I have done most of the cleaning and detail work to the truck, trans, transfer case and motor. I will be taking the engine off the engine stand to change the seal do some more cleaning. I am thinking about putting the trans and motor back together and installing it and one complete unit. I think the work I can do before it is under the truck will make it easier. I did not take the motor out with the trans bolted up so I am not sure what I will run into. I also pulled the fender wells and will put them back on after I build the new exhaust.
