"Drilled rotors" are not necissarily "Better" rotors.
The problem with the vast majority of drilled brake rotors is they are simply made in china GARBAGE, that has holes drilled in it.
AND, Drilling holes makes things worse not necissarily "Better"
THE issue on Gen1 & Gen2 brakes (And the 1993-94 Gen3's), is that the steering knuckle that locates the inner brake pad tends to wear and this causes inconsistancy in the brakes.
THE improvement to this braking system is swapping on a complete 1995-97 Front axle with the vastly superior two piston brakes.
They don't necissarily stop you a huge ammount better, but they DO give the same pedal feel every time you put your foot on the pedal.
This means that each time you try to stop the result won't be a suprise.
"suprises" are more often than not unplesant...
