BlackBII's white ranger
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
keeping the 2.3?
BlackBII
Ranger Custom
Truck of Month
984
UT
Yes sir keeping the 2.3, I knew I was pulling the trans and tcase, and I wanted to do some work to the motor, so I pulled it just to make things easier.
Pressure washed the motor, all new stuff going on. New timing belt/tensioner, water pump, oil pan gasket, rear main seal, valve cover gasket, sparkplugs, thermostat, etc. Should be leak and maintenance free for a good while
BlackBII
Ranger Custom
Truck of Month
984
UT
New flywheel, clutch, throwout bearing and slave cylinder
:icon_thumby:
triumphrider-1
14
Port Huron, MI
Ford F150
3.7L
Turbo! You forgot about the turbo!
BlackBII
Ranger Custom
Truck of Month
984
UT
Ha! No turbo on this one. With small tires and 4.56 gears, this should be quite speedy. This is going to be a in town commuter with camping capabilities.
I do have an entire Turbocoupe setup I could use....but I don't need 200hp in this little danger ranger.
:icon_thumby:
982WDRanger
07/2013 OTOTM Winner
Chazy, NY
4.0L, Bored .030 over!
I used to have a 4cyl. in my truck.Those things are tough as nails and will do a lot for what they are. I was pushing 32x11.50s with mine and 4.10 with no issues. Nice to see people build truck that don't need to have huge motors to be awesome:icon_thumby:.
BlackBII
Ranger Custom
Truck of Month
984
UT
Yeah i'm not towing any horse trailers or anything with this truck, so the 2.3 will be plenty, especially with the low gearing. Plus, this truck should get decent mileage
cammeddrz
23
Ford/chevy
efi 350vortec
you need to bring that one out to the next one......
BlackBII
Ranger Custom
Truck of Month
984
UT
BlackBII
Ranger Custom
Truck of Month
984
UT
Everything back together and it drives awesome!
88_Eddie
155
Raleigh, NC
2.9L, 4.0L
that was fast, what's next
BlackBII
Ranger Custom
Truck of Month
984
UT
Now that the engine and trans are functioning properly, next is a 1354, which I have yet to find a good one, and then Dana 35 in the front and a 7.5 in the rear, both with 4.56 gears and lockers, all with about 2" of lift and new poly bushings. Then, it's on to the interior, and then eventually, paint, new headlights, grille, and bed liner
:icon_thumby:
BlackBII
Ranger Custom
Truck of Month
984
UT
More parts in the mail!
Stinger mat, supposed to be better than Dynamat
New shocks
Grunizzle
01/2013 OTOTM Winner
U.S. Military - Active
Albuquerque, NM
4.0L V-6
Why put a 7.5 in the rear with gears and not an 8.8?
BlackBII
Ranger Custom
Truck of Month
984
UT
Well I already have the 7.5 setup with gears and a locker, its from my old bronco 2. I could get and 8.8 and regear it, but since I already have the 7.5 I may as well use it :icon_thumby:
