Blackwidows 350 sbc street truck build
RangerFabWorks
The O.G blackwidow67
715
Lexington, North Carolina
302
Just finished up the build thread.. I am glad to see the Cragar SS wheels are still in the mix... In my opinion those wheels made the truck stand apart from others. Amazing job as usual. :drool:
Just trying to keep up with you multi :icon_thumby:
RangerFabWorks
715
302
Welp kiddies. Here’s a lesson in physics for you.
A 400 horse engine
A stock 700r4 with a 2200 stall converter
And a very heavy right foot
Can we guess the outcome?
Blew the farggin front pump right out of her. And I’m pretty sure the 2-3 gear is busted. Whole bunch of grinding going on when you try to stick it in gear.
Th350 time!
17,867
SW Iowa
If ain't broke you ain't tryin' :icon_thumby:
RangerFabWorks
715
302
I can’t say I was trying real hard. But with 400 horse. I wasn’t driving easy. I’m shocked the front pump exploded before the 7.5 rear did. Oh well
Eventually I’m going to stick a 4 or 5 speed in it. So for now the th350 Will work. Just gotta order a 2700 stall converter.
17,867
SW Iowa
Don't know anything about them, common to explode the pump with higher hp?
alwaysFlOoReD
5,102
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Isn't the 700r4 based on the th350?
RangerFabWorks
715
302
Yeah the front pump is weak on the 700 in stock form. Also the planetary is weak. Mine was having a problem with a hard first gear shift. And super soft almost slipping 2-3 shift. It’s days were numbered
Yes the 700 is based on the 350. But the 350 in stock form is much stronger. And has a better gear ratio. 2.54 first vs the 3.06 first in the 700.
alwaysFlOoReD
5,102
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Thanks for the info. I'm contemplating using a 700r4 behind a built 2.3l [supposedly 250 - 300 HP]
RangerFabWorks
715
302
Use the later 700 from 88 and on. They are the stronger ones. And make sure the tv cable is spot on. You’ll be just fine. I’m making 400 horse and I haven’t been easy on the old girl. So I can’t fully blame the trans. Just wasn’t designed for what I do
RangerFabWorks
715
302
New 25-2800 stall converter is on its way. Going to pull the engine and transmission as a package. I’m not happy with the oil pump I used on the build. So now is a good time to change it out.
whwaufmaio
Stafford, VA
3 inch body
Get to it
looking oh so good, Wow. get the dash mocked in there? how'd it turn out?
whwaufmaio
Stafford, VA
3 inch body
Get to it
RangerFabWorks
715
302
Alright. Let’s do this
