bleeding problem
90rangersuper
Pittsville,WI
Hi all its been a while, trucks running good so no need to post, now i had a leak with the rear brakes, replaced the lines and both wheel cyclenders and when i go to bleed them i can have the bleeders cracked wide open and i still have a firm pedal and very little comes out of the bleeders, any help would be great, i was thinking its a RABS issue
JamesC
350 chev/3.0
could be a kinked or damaged flex hose.
Sasquatch_Ryda
Forum Staff - Retired
108
Terrace, BC, Canada
Solid Axle Swap 4x4
40s
Sounds like the RABS valve is clogged. Time to bypass it.
flagport
Cocoa, Florida
2.3L
Follow-up
What was the fix?
Did you replace the RABS unit (which has a history of clogging up over time), or bypass it?.
Just curious on your fix approach. I replaced mine on my 91 when I couldn't get flow to the rear brakes. Expensive, plus a core return.
Happy new year.
Ron
