blowing fuses
BigJohn76
18
George, IA
97 250 7.3 PSD auto
i keep blowing the fuse for the dash, parking, and taillights. it is supposed to be a 25 amp fuse but when the first blew i put in 30s and this last time seemed to last a while but it did it again tonight.
i put in a sony cd player that would dim when the lights were turned on, but we cut that wire when this started happening.
it will blow fuses right away but then it decides it likes one and keeps it for a while. it is starting to piss me off
i think i have a voltage problem because when i step on the brakes or the truck slows down a lot, the voltage drops. is that what is causing this? i have also been told that the headlight switch could be the cause. thoughts?:icon_confused:
bigcountry
new market
check your alternator or alternators cant remeber if the 7.3s have one or two there should be a voltage regulator your could be going out
