blown head gasket question
dave2575
Bay Area, Nor Cal
mostly 88
2.9
"BIGGER HAMMER!"
OK so I have a blown head gasket at no1 but there is no coolant in the oil or valve covers not anywhere. I'm guessing this is uncommon right? Has this ever happened to any one here?
JoshT
1,877
Macon/Fort Valley, GA
Not with a 2.9, but my 99 4.0 did that... twice.
First time was cracked heads, second time was a leaking head gasket. Diagnosing the problem the first time like to drove me up a wall. Had a bad missfire, took it to dealer (too many times) to find out what was wrong with it. They kept telling me I had a bad spark plug, I think I replaced the plugs three times and wires twice in one year trying to fix the problem. Turns out all they were doing was pulling the codes and checking the plugs, never dawned on them to see why the same plug kept going bad. Of course it took a bit before I realized that's all they were doing, but once I did it was time to pick up a compression tester. Sure enough one cylinder was way low. Pulled heads hoping to get away with a gasket change but had them checked, turned out both were cracked. Replaced with new stronger castings.
About a year or year and a half later the problem returned but not as bad. Once again no signs of leakage in the oil or valve covers, but I did notice that I was slowly loosing coolant and assumed there was a small external leak somewhere. Turns out this time a head gasket went but it was my fault. Was using one of dad's torque wrenches, one that was his dad's and probably hadn't been calibrated since his dad passed over 26 years ago. It worked fine for most things it was used for but apparently head gaskets are too sensitive to torque values. Bough a new torque wrench (needed my own anyway) replaced the head gaskets, and haven't had a bit of trouble since. (Don't worry I knocked on wood.)
sfwjesse
New Hampshire
my 93 4.0 did the same thing....one dirty spark plug was all i had for an indication, and loss of coolant. I changed the coil pack before i smartened up and realized it was the head gasket
dave2575
Bay Area, Nor Cal
mostly 88
2.9
"BIGGER HAMMER!"
Ya its really got me stumped, I kept checking my radiator every couple/few days and I had to keep adding coolant. I checked everywhere to find where it was going but there was no coolant in my oil pan, valve covers, cylinders, intake, exhaust, engine compartment, under the truck, or the tailgate. I just dont know where it all went. :icon_confused: It wasn't until the head gasket blew out the side of the block that I could finally find a leak.
