Blown head gasket?
warrior24
Surprise, AZ
I think I have a blown head gasket. I have been having overheating problems and noticed one or two bubbles on my oil dipstick. Cant really tell if I am loosing coolant since I have been flushing it and draining it to change radiator and t-stat. My question is how much psi should I have when doing a compression test. Also how do I preform a compression test? Should I try the uv test thing?
Big Jim M
30
Austin
The test
for a blown head gasket is to fill the system with coolant and drive around a bit.. If the radiator doesn't puke it's coolant out and over heat your gasket is ok. Doing a pressure test on the cylinders will only show you the WORST gasket failure. One which you would already know about from the puking and overheating.
Big JIm:icon_thumby:
warrior24
Surprise, AZ
ok well it has been puking but I think I realized my mistake. To ashamed to admit it though.
Toms01PSD
37
Sanford, NC
7.3
Don't be ashamed. We're all here to help each other. Hell, i'm buying a ranger with a 4.0 on monday. Either the heads cracked or the head gaskets blown.
warrior24
Surprise, AZ
OK I got an after market metal fan because I hated having the plastic one crack, but installed it backwards.
warrior24
Surprise, AZ
Yay no more overheating. So I guess I didn't have a blown head gasket.
warrior24
Surprise, AZ
I feel so dumb like my rep power should be lowered down a notch.
Beef52751
13
Eastern Iowa
LOL, mistakes happen, at least you caught it before it caused any damage.
Toms01PSD
37
Sanford, NC
7.3
I see, so instead of pulling air it was pushing? Mistakes happen, it's no biggy.
