I have a small hole in the frame on my Ranger (http://therangerstation.com/forums/showthread.php?p=1402955). I am planning on fabricating a repair plate out of 1/8" plate steel and then attaching that to the frame via existing bolts (new bolts actually that would replace the old ones already there). Luckily for me it is near 7 different existing bolts or holes including two large ones that hold a crossmember in place.
So, what do you guys think? Is a bolted on repair plate like this legal/safe? I know it would have to be done well and upon inspection ultimately it comes
down to the mechanic looking at it as to whether I pass. I have no doubt
it will be more than safe, honestly my mechanic told me I could drive it
with the rust hole the way it is for at least 2-3 years before it wouldn't
be safe to drive, so I don't see how adding this strengthened area bolted on would make it less safe.
Before I bolt it on the frame (and rest of the underside) is going to be professionally sprayed with Fluid Film. The plate would be painted installation so rust shouldn't be an issue. I plan on getting the truck sprayed with Fluid Film every year before winter indefinitely so I can keep it as long as possible.
