bracket fabbing or not???
Gabe8810
Albuquerque, New Mexico
ok i got new coils for my ranger. they are 8 inch lift coils and my truck and i have 4 inch coils on there now but also have an inch and half spacer so its really a 5.5 lift in the front. My question is is it any way possible to use the 4 inch lift brackets with the 8" coils???
Gabe8810
Does anyone know i do not want to tear it apart to find out i can't do it.
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
No, you won't be able to go more than about 2" more than your brackets are made for. Steering would be fawkin scary with 8"s of lift on TTB anyways.
Bent Bolt
4
Edmonton,AB
Supercharged 4.0 SOHC
Solid Axle Swap 4x4
If you have Skyjacker lift brackets , you could put the radius arm pivots to the 6 inch holes then I think the 8" coils will work.
Bent Bolt
4
Edmonton,AB
Solid Axle Swap 4x4
And yes, the steering will be an issue.
Gabe8810
ya i am going with the 6" lift and probably going to stick in the 8" coils than again i think ill just save the coils for A solid axle swap.
mkpecor
black diamond W.A.
ranger 4x4
2.9
if you have 4'' lift brackets you can us 6'' lift coils, if you have a 6'' lift kit you can use the 8'' lift coils. like SK brackets come with 2 holes on the pivet bracket you would want to use the bottom hole with the 8'' lift coils. but no you cant use them with your kit. you can buy the two front brackets from SK.
Hahnsb2
36
Battle Ground WA
Ford-Dodge
4.0-5.2 Turbo
You DONT want TTB coils for a solid axle, they're waaay too stiff.
Gabe8810
so these coils are worthless?
edit: i can use them did some research and steering won't be too bad and i can still align my truck in specs
zachis4wheeling
Port Huron, Michigan
drof
I ran 6" brackets with 6" TTB coils and 1.5" thick spacers and it worked out fine. The coils I had were superlifts and didn't flex for shit to begin with, so the steering worked out alright. I had the extreme drop pitman arm though from skyjacker so that probably helped a little bit too. I would definitley reccommend when it's all said and done though to go and get an alignment.
Ranger#1
5
lake havasu
if ur gonna git rid or ur 4 in lift coils i want them
