Brake Line
GKM007
Auburn, WA
2.8L V6
I am working on installing a new soft brake line on the passenger side and I cannot get the nut/bolt on the hard line to let loose. Someone He-manned it on and coupled with some rust it is froze.
I have access to only one place to turn it with a wrench, which should be towards the front of the rig, counter clock wise. Sadly it is pretty rounded now from an hour of trying.
Looking for suggestions. I have sprayed the hell out of it with PB Blaster and no luck. I was thinking about doing the hot cold method but my dilema is this... at this point the nut is pretty screwed. I might be better off replacing the hard line at this point and get a new nut, as since the line is flanged I cannot just replace that?
alwaysFlOoReD
5,123
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
Can you get at the other end of the hard line?
GKM007
Auburn, WA
2.8L V6
Not sure? I only traced it where it dipped under the motor, it was dark last night when I finally gave up. I assume there has to be a T-junction somewhere beneath the booster where the driver and passenger split off.
cvar
19
Mazda
4.0L V6
I would just snip off the old threaded nut, as close as possible to the nut, so that you'd only lose 1/2" or 1" of hard-line length. Then re-flare that end, and attach it to your new hose via new nut. You can "rent" a double-flare tool from an auto parts place, for free.
In mine, the other end of that hard-line attached directly to the splitter block of driver's side (LHS) brake hose. It ran along the cross-member below the engine. The LHS hose matched the RHS hose, except it takes 2 nuts: 1 input from MC, and 1 output to the RHS hose. Both hoses were attached to the coil bucket via spring, so it helps to remove the spring, to get some wiggle room to work. I presume yours is similar?
See http://imgur.com/a/sUnMy
I had to grip a stripped nut/bleeder in a bench-vice to remove it from a caliper. PITA. Someone must have used red loctite instead of blue?
GKM007
Auburn, WA
2.8L V6
Mine T-block somewhere else, its just hard line behind the coil bucket. Problem is there is no room to get a wrench in behind there. I'll have to see what kinda of slack I have, I might have to go the cut route. Good to know you can get a flare tool at the auto store.
http://i.imgur.com/2toHHxp.jpg
Looks kind of like mine although my hose is higher on the bucket which causes my space problem.
cvar
19
Mazda
4.0L V6
Taking off the fender plastic inner liner might give more room to work?
GKM007
Auburn, WA
2.8L V6
So ended up pulling a hard line at a junk yard. There is a different route on every one I looked at... Grabbed one from a two wheel drive I thought that I could make work. No dice! Ended up using a 6" chunk from the one I bought and used a coupler to my existing line. I got pretty good at the double flange tool. So far no leaks and the truck will stop on a dime so I will call this a win.
Oh and I do not know why but Ford had a great idea to use red lock tight on all those compression nuts! It was a pain to break them loose!!!
