Brand-New RS Series Cab Length Running Boards by Armordillo at CARiD
carid
Supporting Vendor
Cranbury, NJ
Meet the new Armordillo Release for 2019-2021 Ford Ranger - RS Series Cab Length Running Boards. Now you don't need to compromise between the rugged appearance and a convenient step, as this setup provides the best of both worlds. They combine an ergonomic, tubular construction for maximum strength, ultimate durability, and an eye-catching design.
These running boards will help to protect your truck's body and paint from stones and road debris that gets kicked up while driving. They are completed in a black powder-coated finish for aggressive good looks and long-lasting corrosion resistance. Being easy to install, they require absolutely no drilling and come with all necessary mounting hardware.
The new Armordillo running boards will be a perfect upgrade for your Ford Ranger!
Armordillo® - RS Series Cab Length Black Running Boards
Notes:
- Mounting brackets included
- No Drilling required for installation
- RS Series Running Boards are simply made to serve a function as a running board and not a rock slider
Features:
  • Tubular construction for maximum strength with reversible step plates
  • Made from road-tough materials for durability and strength
  • Extended tire coverage for aggressive wheel and tire fitment
  • Easy, bolt-on installation with no drilling required
  • No drilling required for most applications
  • Added protection against road spill, stones, and rock debris
  • Powder-coated finish for superior corrosion resistance
View the full list of Armordillo Products: https://www.carid.com/armordillo/
Uncle Gump
Token Old Guy
13,480
Ottawa IL
Ranger/BroncoII
4.0L SOHC/2.9L
I kinda like the looks of these... only made for a supercrew.
They apparently didn't think it was important to show a pair installed on the truck... nothing on the website either.
