- Sep 7, 2021
- 56
- Boise ID/Camarillo CA
- Ford Ranger
- Engine Type
- 2.9 V6
- 2WD / 4WD
- 4WD
- Total Lift
- 3"
- Tire Size
- 31x10.50R15
This morning my son nailed a curb and split the leveling spacer (his words, not mine) in his 86 4wd. We do not know what coils are on this truck (stock or aftermarket). I "assume" it has stock coils and a 2" spacer lift. The rear has a lift block that looks to be about 2" and the truck sits very slightly nose down. We have added Toughcountry 2" drop brackets for the I-beams because camber/handling was pretty bad when we bought it but now (prior to nailing the curb) alignment and handling is pretty darn good.
He does not want to put more lift on this truck right now and is fairly broke so cost is important...but he wants to fix it correctly, too.
I think he should order a set of Skyjacker 1.5-2" (part number 132) front coils and just chuck the spacers. Again, I assume he has stock coils that are probably fairly sagged at this point so a 2" lift coil should get him back to level.
The problem is, if he already has leveling coils in there and we replace them and chuck the spacers, now he is 2" nose down.
Question: Is there a way to identify the stock coils vs aftermarket? Are the stockers marked? Do stock coils have more or less coils or thicker/thinner wire compared to others?
What would you do?
What would you do?
