Mine started as a scrapped U-Haul U-shaped axle, with a spring on each side and the angles it was welded to on each side had been cut just beyond each spring. It was advertised in the paper and I went to see. He had a barn yard full of schtuff and I picked an axle and paid the $25.
a couple years or so later I was working on a Spa and Tub showroom and warehouse and as we we wrapping it up, and each company was packing up, the framers had some angle iron to dispose of and I built a ladder rack for the 87 Ranger and hauled a load of it off
I got a tongue, a light kit, and a tongue jack at tractor supply and stowed it away. My unemployment ran out and I took a job with another company building a nature trail, and day one I got stuck with 2 day laborers and a trailer load of 20ft 8x8" soaking wet Ground contact treated posts to cart down the side of a hill and stand up in holes that were already there. It was one helluva long day, and around midnight I came out of bed with more pain in my shoulder than I could bare. A gf told me to go to ER and I got put on 5 lb lift limit.
After a while I began getting more aggressive with using it, but the pain was so intense it was good I had no close neighbors. I had hoped to do a better job with it but wound up with a small HF 220V stick welder and began welding. I used a 10 inch miter saw with a metal blade to cut, and those 1 1/2" 10' angles to build a trailer onto that axle frame.
I had six hole rims on the 80 Chevy LUV that fit the old axle and that got me on the road, but I knew it was not safe, because in case of a flat, the U-bolts on the axle would hit the pavement.
I had set up an appointment to have it inspected and certified by the TN Highway Dept, and even as he asked questions which included any safety concerns I replied "none".
My shoulder was injured permanently, and nerve damage to this day affects my spine and back but I've lived with it. It took all I had to pay off my landlady, that woman carried me the best part of two years, and when I gave her the check she all but cried.
I bought a factory axle for the trailer and tossed the drop axle, and had a safe to use 4x10 ft trailer with 2ft sides all around and a drop tailgate.
So in effect, I built a trailer onto an axle, and then replaced the axle
But, it made 4 heavy duty loads 600 miles to home, and an empty 600 mi back to TN for 4 round trips
And those angles on front of that trailer today are where I go when I need an anvil
