Broken oil pan Bolt
GotBronco-itus?
ABQ New Mexico
Currently swapping in 302 V8
So I was taking off the oil pan on my 302 and one of the bolts snapped off, its real small and I was wondering what is the best way to take it out? using an easy out or?:icon_confused:
littlezell
Young Harris Ga
is there any of it sticking out??? and um how much room you got to play with?
GotBronco-itus?
ABQ New Mexico
Its not even sticking out a little, and the engine is out on a stand
doorgunner
Lab Rat for V.A. hospital
MTOTM Winner
2009 Truck of The Year
516
New Orleans (8' below sea level & sinking)
350+1
N/A
3/4
23570R15
JESUS Loves Ya!
well....use a center-punch to mark the middle of the bolt to help the drill(bit) start drilling easier.......if you could get a left-handed drill(bit)--it might back out the rest of the broken bolt while you are drilling a hole in it for the easy out to fit in!
GotBronco-itus?
ABQ New Mexico
Thanks for the help! Im going to get the left threaded bits and easy out with in the next few days.
3,615
Do you know why it broke?
I have had some success removing broken bolts by drilling a hole about 1/2 to 3/4 (depending on bolt size) or the bolt's diameter and then pounding the next sized torx bit into the hole. The points dig in and grab and will work better than most easy-out setups.
Be careful though, it doesn't work well on off-centered holes and it doesn't work at all on rusted together stuff or crossed threads, and if you snap a torx bit off in there you are done. It takes special machinist bits to drill through them.
