Broken wire
scrapper
63
central IL
1975 302
I was putting new intake gaskets and fuel injectors, and noticed this wire. it seems to have broken off from something? Its a 2.3
The big plug is the bottom plug on the computer? Its the box bolted to the intake manifold.
Haywire6000
Lewiston Maine
1997
2.3 Turbo Four Plug Head
The big plug goes to the bottom of the Ignition control module or the top, there should be two of those. The one with the wiring running to the crank sensor goes on the bottom.
scrapper
63
central IL
1975 302
What about the broken one? The other two plugs are hooked up. I'm just not sure about the broken one.
alwaysFlOoReD
5,100
Calgary, Canada
'91, '80, '06
Ford, GMC,Dodge
4.0,4.0,5.7
I don't know the 2.3, I've never worked on one. However, I've seen single wire leads on the oil pressure ( idiot light ) sensor and the water temp ( idiot light ) sensor on other engines.
Sent from my XT1032 using Tapatalk
Haywire6000
Lewiston Maine
1997
That single wire plug i believe goes to the noise supressor on the coil.
scrapper
63
central IL
1975 302
Hopefully I will find it tonight.
scrapper
63
central IL
1975 302
Well, I cant find any place for the wire to go. It almost looks like 2 wires but they are really small. The only thing on that side is the gear box, crank trigger, wire loom that goes to the starter. I just started it and it runs okay, the miss is gone. It has really low idle. When I first started it would die as soon as I let off the gas. I drove it for a bit going 65. It seemed to have less power but I got it in 5th gear, it don't usually do very good in 5th gear because of tires and gears. It wasn't having any problem. It would not go over 65 though. :annoyed:
