Bronco 2 turbo project...
Sevensecondsuv
7
Northern IL
Many
All Fords!
Many
Mine wouldn't boost when I first wired it up either. Turned out I had mis-wired one wire on the VAM. Fixed that and she runs like a bat outta hell. For a relatively stock engine, as it looks like you've got there, the stock EEC system should be more than plenty to run it right.
motaaa
its not worth the shipping.. jy it.
Does anyone have a dash/ gauge wiring diagram for these things. the 2.8 dash doesn't have a tach so i got one out of another ranger in the back yard but the wiring is fubar.
We just put new fuel lines and a 2.9 tank in it. I have a volvo inline fuel booster pump that were going to run for now.
what wire did you hook up the tach to?
dieselboy740
86 bronco2
still haven't got that to work yet. But we got a la3 and did some rewiring and repining and it runs good now.
dieselboy740
86 bronco2
um 19psi makes a scary bronco II its stupid fast. Videos soon
I just realized there are only 2 pics. More to come on that note then sorry. It has a stainless top mount header, .48/.60 turbo, cut rotated square intake, 3" fmic, alum rad, recirc bov, dual optimas and other items. Is already taken out 1 rear end. We have a explorer 8.8 but the driveline flange is different.
dieselboy740
86 bronco2
well its forsale 2250 obo. No recent pics ill try to get some but here are some old ones
1986 Ford Bronco II 2.3L turbo 4cyl, 4x4, project, runs good, very fast, motor out of ‘86 SVO mustang, new aluminum intercooler, all aluminum radiator with 2 12" electric fans, new in-tank fuel pump/frame-rail booster pump, PS, PB, stereo with i-pod hook-up, 120 degree rotated intake, new injectors, center-mount equal length header, dual batteries, blow-off valve, needs carpet and front seat belts, $2250 obo, must sell quick, Located in san diego "ramona" dieselboy740@yahoo.com
NEALD
I know this is an old thread but did you need to fabricate any mounts to put the 2.3 in there? Just wondering because I'm looking to do this swap soon. Also did you use the bronco II harness and just re pin at the eec connecter?
